DOT issues
pimppride
California
this afternoon I fired up my small lineup to get some gaming on, and my DOT is giving a little fit
no sound, but when you hit an input you hear a pop or crackle from the speaker, the obvious screen issue, looks like its more than one thing going on?
ill have to crack it open and check the voltages, and maybe time to install those new ribbon cables
any suggestions are appreciated
in test, grid
picture.php
on boot
picture.php
picture.php
If the pcb's have the original ribbon cables, I would install them first and retest.
If you have the same issue, you should then measure the +5v on the power supply board and then we go from there.
I feel relieved, it was just the ribbon cables, I thought it had new cables still because this game has been pretty bulletproof since I got it ( and breakdowns usually are not the easy stuff )
back to 100%
thanks again
picture.php
