Donkey Kong Wiring..Help!!
That is a jamma harness that can be used,but you need a jamma adapter and a switching power supply to use it.
It uses the edge connector instead of the little black connectors.
Oops no adapter needed.
IT says nintendo classic harness on it... But theres no connectors.. so I cant use the damn thing..
I don't think Bob will take returns. It can be used if you can get the other connectors for the other ends and use a switcher since the power gauge is too big on that harness to go into the 9 and 10 pin connectors. You're probably better off finding a used harness or wait for the 3rd run of DK harnesses that Dokert and I build, but I'm not sure when that will be.
I bought and still have one of Bob's DK harnesses before I started building them and I have no idea what I'm going to do with it. - Barry
Im starting to make alot of expensive mistakes... Anything else these 30 dollar hunks can be used for?
It happens, I've made my fair share. If you use an edge harness you'll also need a rainbow cable if you didn't know. - Barry
I had The Fader send me his 2 harnesses so I could put on the ends and make him a couple CP harnesses. I finished the harness mods today so I'm posting pics of it for him to use when he hooks it up. - Barry
Pic1 - harness from Bob Roberts
Pic2 - harness with the ends ready to go
Pic3 - It works!!!! I knew it would but Itest them to be 100% sure.
A few more pics.......
Pic1 - PCB connection
Pic2 - Power supply connection
Pic3 - Video connection
Pic4 - Audio connection
Pic5 - CP connection
Thanks again Barry. While this might be easy to alot of you, trying to get the 24 volt wired to the right spot and getting all the power wires in the right pins would have resulted in atleast 3 fried boards for me.
