donkey kong sanyo color bleed
djdaveofkc
Gardner, Kansas
hey guys, barely above the red levels on my donkey kong their is a purple color bleed that i can't get to go away. I've tried every nob and cutoff on the neck, i've tried the contrast(i believe) next to the sharpness, and i can't figure this out. Please help. Thanks
canned responce to "19" Med Res. WG weak green?" topic
Rejuvenator, Rejuvenator, Rejuvenator.. if that doesn't work you have a cheap rejuvenator or you have a very low electron emission due to depletion. It could be other things however if you ruled it to be the tube that is your options. Double check your heater voltage. You could do a hv hack to accelerate / pull your electrons howerver that is dangerous, against x-ray rules & could destroy components / chassis board.
