Dokert
I think VR362 is an error in the scat, and it should be VR451.
Put the resistor back where it was and try it again with some fresh solder. May have just been a cold solder joint between the resistor and the pot.
Do you think the pot on the game pcb that adjusts sound (I have the 2 board version) could be the cause of the weird noise I'm hearing? I did tweak that before when trying to fix the sync issue (before I remembered I have a manual and looked up what it actually does).
The pots on the game PCB control the vertical and horizontal centering, not sound.
Just thought about something you said early on, went back and checked to make sure. C471 could be your problem, it is in the affected circuit.
There are two pots on one pcb that do this, yes. There is a pot on the other pcb that has to do with sound.
Ok everyone, got the cap kit, replaced all caps except C408, C471 and C406 (Bob shorted me 3 caps apparently).
The hum is normal on all DK series boards, you can install a 2200uf 16v cap in the speaker output accross the pos/neg and it will remove the buzz/hum.
Congrats on the monitor.![]()
