Donkey Kong not powering on
Can I ask where you purchased this 2nd chassis? If you are not comfortable saying the exact person, then was it purchased here on KLOV or elsewhere?
It was purchased here on klov. They did say I can send it back if I'm having issues with it.
Yeah I will be sending it back and sending mine out to get repaired.
So I got the first one that had a crack back getting this when I power it on. I am still waiting for my original one to come back from repair.
Just stop using that one, you'll burn a hole in the middle of the CRT's phosphor. I assume it's just a dot in the middle, and the flare is the from the camera, but it's not deflecting the beam at all and likely the flyback brightness is turned up way too high.
Thank you I will stop using this one and just wait for the other one without the crack to arrive.
In the meantime, can you post some pictures of how you have everything connected? Just to check if you forgot to plug in the deflection coil or if there's another issue you might not see. Please take wide shots that show everything, extreme close ups aren't as helpful.
Here are the images let me know if these work.
Got the fixed chassis back same symptoms blew the fuse and smoking on the thermistor on top.
Unplugged the degausser and got this on the screen no smoke and screen turned on.
