modessitt
Working on a DK cocktail. When you turn it on, you hear "BOING" pretty loud (because I have both volumes turned up).
Have a TKG-3 4-bd set that has a graphical issue and no sound. Swapped in a TKG-2 4-bd set and the graphical issue is gone, but still no sound.
Now, the TKG-2 was missing the two sound ROMs on the SOU pcb, so I used the ones from the TKG-3 set. I saw somewhere on here that they used the same ROMs, but that might not be accurate.
Anyway, I tried using the TKG-3 SOU pcb with the TKG-2 set, also, but no change. I can turn up the volume and hear hum. Since I hear the "BOING" at power up, I'm assuming the sound amp is good. I did some reading on Brasington's site and tried swapping the 8035 between the two SOU pcbs with no change.
So I'm thinking I either have bad ROMs, incompatible ROMs, a bad 8035, or some other issue.
Unfortunately I haven't been able to find a ROM set online for the 4-bd sets.
Any thoughts?
Any thoughts?
