Donkey kong II installation
Boo32
Richmond, Virginia
Donkey kong video ram error
I installed donkey kong ii and now have a bootup/selftest screen. Had been having some video problems. Bootup shows videoram 6r is bad. Is this a matter of replacing a chip? If so, can someone point me to the type of chip, it's location on a two board donkey kong and where I can buy a new chip? Also at thr bottom it reads bootup failure 008. Thanks
It is on the video board. You should see a grid of letters and numbers that run along the edges of the board, where these cross is the location of the chip. You should also see a "6R" screenprinted on the board next to the chip. MikesArcade sells that RAM. Hope that helps
Looking good
With help from klov, I found the 6r on the video board and reseated it. So far so good, thanks for the help.
