JamBurglar
I've got a Dokert/Flagg harness setup in my DK so I can swap between DK and DK Jr. I don't swap that often but I do go back and forther every few months.
When I switched to Donkey Kong and turned on my machine I found that I could not move jumpman/mario down. I removed and reconnected the edge connector several times and found that I would lose various directional controls and jump. At one point I wasn't getting any input from the control panel.
DK Jr. works perfectly in the same cab with the same harness and everything.
As a cross-check I pulled out my original DK control panel harness (the mulit-connector style). When i hook that up I get all my controls back and everything is fine.
Dont' know if it helps but here's a couple high-res shots of both sides of the edge connector.
Is this something that's fixable?
