Does anyone have a schematic that shows where each wire goes to hook up a donkey kong control panel. After hooking the buttons & joystick back up none of the buttons work. Maybe a bad ground connection? Thanks!
For NOTHING to work, it's got to be a bad ground. It should be pretty easy to see which one ground is, it's on the outside bent lug on each microswitch.
I've got a ground wire thats not attached. It is split three ways, going to the speaker, contol panel latch, and.....where is that third connector suppose to go?
