daniel64485
I picked up a Space Firebird board set from a Nintendo cocktail this weekend. I am thinking about installing it in my red Nintendo cabinet, I am looking for just the wood part.
some what handy. I was going to buy the jamma adapter but he is not shipping to the USA right now. I know its not going to be easy.How handy are you? That boardset has a unique pin out that would require you to get a pin to edge connector that would require mapping.
The radar scope button holes look correct but the joystick is different. I figured I would need to drill holes for the correct layout.Also, be aware that it would have used a Radarscope style panel, having a donkey kong style panel would be very uncomfortable.
Like previously mentioned, pre-radarscope games also had a different pinout, to the pp7* power supplies will not work with this game.
Are you sure about that? I am pretty sure that the joysticks on the cocktail table are different from the upright. I was under the assumption that space firebird used the radarscope style joysticks for the upright.The radar scope button holes look correct but the joystick is different. I figured I would need to drill holes for the correct layout.
That might be correct but I have not found any picture of a upright Space Firebird cabinet. I was going to use a regular joystick with a Nintendo Joystick 2-way Guide Plate. Mikes arcade has some of the harness I will need.Are you sure about that? I am pretty sure that the joysticks on the cocktail table are different from the upright. I was under the assumption that space firebird used the radarscope style joysticks for the upright
I did that originally with my Radarscope before finding an original. I used a router to make the slot for an original joystick.That might be correct but I have not found any picture of a upright Space Firebird cabinet. I was going to use a regular joystick with a Nintendo Joystick 2-way Guide Plate. Mikes arcade has some of the harness I will need.
No I was only able to pickup the pcb set and crt.I did that originally with my Radarscope before finding an original. I used a router to make the slot for an original joystick.
That said. You mentioned getting parts from a cocktail, if you have the cocktail control panels hit me up, I am in need of those.
