Donkey Kong - Bad Vertical Adj Pot
oktobernv
Henderson, Nevada
I have a bad POT on my Donkey Kong main board
It's the "vertical position" adjustment POT at location "VR2"
The board says 50k / 30k
I found this on Bob Roberts site http://homearcade.org/BBBB/ninpots.jpg
I'm not sure if I need the 30k pot or the 50k pot for the Vertical Adjustment at VR2??
Any advice?
Thanks as always
Rob
I checked the current pot
it's old and if there were any markings on it....they are long gone :(
Any know which is the correct pot for the Vertical adjustment?
50k or the 30k?
The board is labeled saying it can take either. I would install 50Ks as you can go from 0-50K resistance, the 30K would obviously max out at 30K. You will get more adjustment capability with a 50K, it will just be more sensitive to adjustment.
