Donkey Kong 4 Board image problem.
Straker
Ludlow, Massachusetts
I have a board set that currently contains 8 Ball Action roms. The problem is that in action when the balls pass through certain points on the screen you see a part of the ball on each side of an invisible line. Also on the Intro Screen there are obvious blank lines through the title. I think this problem is on the clock board since I switched the clk board out with another four board set and the problem showed up there also. Attached are a link to the pictures of the problem. You can see in the picture of the pool balls that the cue ball and the red ball are split with one side being in one place on the screen and the other side in a different place nearby. Any idea what is causing this?
http://www.flickr.com/photos/8562949@N03/sets/72157627108644418/
