chris25810
Donkey Kong 3 PCB with cage $65 shipped
I used this for a short while as a test rig for sanyo chassis rebuilds and no longer need it. The board works however, after it warms up a bit it does display a mild case of the vertical jitters. I know that the pots on the board can cause this and i've never taken the board out of the cage to investigate. The board works, it comes with the RFI shield, and has no graphic issues so this could be a very easy and inexpensive repair. Send a pm if you want it.
