I found that I have no video sync
Look like a broken pot on the video pcb.
i'm guessing you've ruled out the header connector pin and the wire has continuity from connector pin to connector pin
maybe a double check of the harness connector pinout is the same ???
any problem with the monitor before or no
good luck
yup.. check the two pots to see if they work or are connected to the PCB OK (V1 and V2 I think they are labeled?)
they kind of stick out and can get broken off or damaged pretty easy.
I had that happen to me once when someone shipped me a board set. The V2 pot broke right off in shipping and screen looked pretty similar.
The pots wouldn't be shorted, they would be physically broke.
Got home and messed with the horizontal hold and everything is good as far as the sync. Now this is what i have.
Looks like blue drive and gain, possibly screen and the brightness pots need adjustment (there are 2 brightness pots - one on the remote board which is easibly accessible, and one sub-brightness on the chassis, which is in the upper right quadrant of the board, if you are looking at it from the back...have to come at that one from the side).
