RandomKG
despite no real knowledge on wiring, i do have lots of successful experience manually figuring out ways to connect MARS AE 2600 series but i'm stumped a bit on ICT.
i have the 12v A6 dollar acceptor with its 30 pins and the harness that is outputting 9 pins. i've looked in the manual and can see what i hoped for: 12v power and ground, credit relay and credit ground.
only problem before i start stripping wires is that there are also one more wire each plugged into the 12v power and 12v ground.
12v power has a red AND a black
12v ground has a white and a brown
do i just take the black along for the ride together with red at the crane's 12v power and the white and brown along for the ride together at the crane's 12v ground?
and then the blue and purple go to the credit pulse/ground as expected?
