Dokert's Repro Sinistar Harness
djw90
spokane, Washington
I was so lucky. I was able to snag Sinistar Harness #001. My Sinistar works but someone added a switcher somewhere down the line. It will be so nice to be able to put this thing back to original glory.
Thanks Dave once again your Harnesses are top Quality:cool:
I see Dokert is doing another Defender harness run, might need one of those too!!
Is it completely new from the ground up??? New connectors and all that??? I wouldn't mind running all new wiring through my Sinistar Cockpit.....
Brand new from the ground up with new connectors featuring Trifurcon pins and wire colors matched to the scat. Also has the 4164 RAM wiring mod, allowing the end user to select either 4116 RAM or 4164 RAM without having to build an adapter or hack the harness.
