Does my Rush the Rock sitdown separate into two pieces?
bobwired
Ft. Lauderdale, Florida
Picked up a Rush The Rock sitdown, but the only way it can make it into the house is if it separates. I tried taking off the steel side plates and still can't get it to come apart. Does it separate? It looks like the rear seat portion is a separate piece from the main section with the monitor. Please, I can barely play my games in the garage due to this monster taking up all my space and I want to move it to my back room.
Thank you
rush the rock
It must be a san Francisco rush,they don't come apart,rush the rock Alcatraz does,I have both,and the guy I got it from cut it with a sawsall,I just put a rubber mat over it and you can't tell it was cut,good luck
It is the alcatraz edition.
The questions are:
Is it an original San Francisco Rush that was upgraded to the Alcatraz edition?
(Then, it's a one-piece cabinet.)
Or, is it a factory-dedicated Rush the Rock?
(Then, the cabinet will unbolt in the middle and separate into two pieces)
The questions are:
This^^ Time to get out the chainsaw.
I just picked up one today :) you can definitely tell if its a conversion if your side art does not say rush the rock on it. Mines a fixer upper for sure, lots of dirt. Scrubbed a bit today and there is still a lot of black on the green seat, any tricks to getting that off easy?
I just cut mine, if you have those big metal plates like you said you should it'll stay together just fine. Just take a reciprocating saw to it. You can't even tell you cut it in half if your lines are straight enough.
Mr. Clean Magic Erasers...lots of them. Oh, and patience.
Here's what you need to look for if it's a dedicated RTR cab, 2 bolts on each side, pull it apart and remember you have 4-5 connections between the two halves that you'll have to unplug.
This is what my cab looks like for reference:
