Ufortunately I'm having a hell of a time with some roms and a GF board...no matter what I seem to do its not working, and I'm starting to suspect its not the roms but something else.
Mame rom set is basically for 2708's, but pretty much all the GF boardsets I've worked on so far have been 3604's or 7641's, which since there's 8 I'm assuming are along the lines of 3604's.
The mame set doesn't match what the 3609 set has either - 3 bytes are different, but I haven't had the time or motivation to figure out why they're different (yet).
Ironically I'm working on Gunfight rom issues tonight, so if I have an extra 2716 I'll fry one up and let you know if/how it works![]()
WAIT! The problem is that the image he posted is for a smaller rom - you have to merge those roms together then split them up in half for 2716's. I have the 2716 versions at home I was hoping to verify they worked before posting up.
Ok, so it took me a while to sort out the numerous issues I was having, most of which were my bench power supply being a P-O-S. Anyways, I verified this free play hack DOES WORK on real Gun Fight hardware, both the original actual hack and the second version with the FREE PLAY verbageI also verified the side-effect that if the board is coined, it will always have that credit and NOT run the attract mode, so you may want to disable the coin door somehow (Piece of tape on second pin from right on larger top edge connector of daughter board works too.).
If you're single rom modding, and you already combined the images into one big image, here's the changes to make:
The addresses to zero out for the actual hack are 0x576 and 0x577
To add the free play verbage....paste this data at F99 (so F99 to FA7):
46 4F 45 45 40 4E 4A 41 55 40 40 40 40 40 40
I verified this free play hack DOES WORK on real Gun Fight hardware, both the original actual hack and the second version with the FREE PLAY verbage![]()
