Does Blitz have to use optical sticks?
Deadpool66
Minnesota
Ive got this sweet conversion cab with blitz in it. Only problem the guy who converted it did not take into account the shallow cp. My question is can I use 8 ways with blitz or are there low profile optical sticks?
My only other choices would be to cut new tops for the control panels or cut holes in the bottom so they will close. I would prefer to do neither.
Check the manual. I had a blitz 2000 gold, and I think it had a dipswitch option to change the style of joystick. I have heard you will see a difference in play since the optical is like a 49 way or something so the 8 way wont have the players move as smooth. But I could be wrong.
agreed with Umortal377 you can use 8 ways and does play okay, not smooth and fluid as per the 49way but still doable
I got them to fit by removing the spacer on the joysticks and trimming the grommet with my dremel. Now I just need to get the cab in the house in test them.
