Does anyone know what joystick this is?.
Ace20
Essex, Chelmsford, United Kingdom (GB & NIR)
I am looking to replace this joystick for another the same or just find the missing parts. The machine is a Deco Burnin' Rubber.
Looks like the "actuator" is either missing or has moved to where it doesn't contact the switches.
I had one of those laying around from a couple years ago, but I'd have to dig through some boxes to find it and see what shape it's in.
Well, it looks like the joysticks that were in the Deco cabinet i had are a bit different.... but the principal is the same on your missing piece.
You may have some luck going down to a hardware store and looking for a metal "spacer" of sorts that will fit. Looks like yours has threads for a nut to hold that actuator on as well. (mine just has a groove for an E-clip)
The spacer just needs to have an inside diameter to fit the shaft and have an outside diameter to just barely touch the switch actuator levers. And the length will have to be where it seats all the way up in the joystick and comes out to where the flat spot is where the threads start.
Heck, a machine shop may be able to wittle you one up also.
Just a note - If it was missing when you got the cabinet, I wonder if it came loose and fell off into the bottom of the cabinet. (I've seen stranger things happen)
