Does anyone know the dimensions of Time crisis 2?
oh, dimensions.
Which one? The one with CRT's in it is just roughly two average arcade cabs wide and can be taken apart from one another. Even in a Ranger or S10 you'd have no problem.
The one with the rear-projection monitors I'm not so sure about.
I laid a Nintendo vs down in the back of it between the wheel wells with the top touching the front of the bed and I had two feet left over at the other end and 8 inches on either side.
You should easily be able to fit both if it's the CRT version. Just stand them up.
nice score!!! and 5 hrs away im surprised no one else scooped it up.
you should be able to pull the disk hdd and memory card from the left side. its a ps2 in there... although i heard some stuff is keyed for the unit.. im not sure what and hope someone more knowledgable chimes in!
You're thinking of Time Crisis 3. That's on System 246, which is essentially a PS2.
TC2 runs on Namco System 23.
