Does anyone here have a PLAYCHOICE 10 cabinet?
qbass187
Suffield, Connecticut
I'm almost done my rebuild of a butchered Punch-Out cab into a PLAYCHOICE 10 but there's a few details that I can't seem to get from the mostly undetailed manuals.
Like the size of the 2 smoked plexi panels that replace the 1 piece Punch-Out plexi and what the heck a "JM Bezel" is.
If anyone here has a dedicated or converted PLAYCHOICE that could answer those questions for me I'd really appreciate it!
Thanks, ERIC
I have dimensions for the smoked glass, but point me to what you are calling the "JM Bezel" or where you got that term.
Here is the glass info I got off another member
Glass size
13 3/4" x 23 9/16" TOP and 16 3/4" x 23 9/16" BOTTOM.
The bottom glass is 23 9/16" wide, 16 3/4" high, 3/16" thick. (I took it out and measured it, so this is quite accurate; about 3" of the glass is sitting behind the control panel.) It's also got a pretty dark tint on it that appears to be the color of the glass (probably comparable to something like 20%-25% tint on a car window, but maybe darker).
The top glass is the same 23 9/16" wide, 3/16" thick, same tint. Not sure of the exact height b/c it looks like a pain in the butt to get out, so I didn't try. The height of what I can see is 13 1/4", but there's probably another inch or two behind the wood at the top of the cabinet. I may take it out this week or next to clean the glass, so I'll let you know the exact measurement if I do that.
Someone mention having the two pieces and might be interested in selling. I believe they were from Texas, maybe gsrogers PM him and ask. Plus if he has them loose he may be able to measure it easily. I think davez had a picture with the glass as well so if you PM him he might be able to provide some info.
That's great! Any help you could give me with the dimentions would be greatly appreciated. The so called "JM Bezel" apparantly is installed over the bottom monitor...according to the manual that shows the conversion from PUNCH OUT to a PLAYCHOICE.
I'll find the manual and post a link in a few minutes.
I've never heard of it but It apparently attaches over the bottom monitor with some sort of a velcro loop. My suspicion is it has something to do with the light gun and how it interects with the monitor.
ERIC
YOU ARE AWESOME!!!
I really appreciate you getting that info for me.
Ok, I see where you are got the JM Bezel. Unfortunately, I don't have any info for this. Looks like a variation of the black bezel around the monitors compared to the PO cab. Not sure exactly what the difference is. I tried to see if I could get the bezel reproduced used in Punch-Out, but didn't get very far with it and don't want to bug the person too much.
Here's the link.
http://playchoice.riemen.net/downloads/manuals/pc10_Kit.pdf
Yeah, I have no clue what it is. Like I said, I think it has some function for the light gun. I haven't installed the lightgun on my PC10 yet so I will find out soon enough if there's a problem. The illustration shows it being installed over the black cardboard valance on the bottom monitor.
I don't know, I appreciate you helping me out with the measurements that was a HUGE help. I'm actually going to order them from smokedplexiglass.com . They will apparently custom cut them if you get them the sizes you need.
Thanks again,
ERIC
Post your question under the wanted section and someone will get back to you with a price.
Thanks for the suggestion. I actually just needed the dimentions because I'm going to have them ordered/cut from smokedplexiglass.com since there's nothing special about these pieces, no artwork or anything.
Thanks for your help though,
ERIC
FYI, the original was glass not plexi.
