Just lack of knowledge of the 27c160 eprom
I needed a way to shut down the other two, when I thought I had it , it seemed there was still interference with the other chips
Were you pulling the CE lines high of the 2 roms not being used and the CE low of the rom selected?
Did you have the byte pins high or low? This wouldn't matter if using the 3 individual roms. It would matter if using the 27c322.
If this rom is used as a 16 bit rom (probably is but I don't know for certain), then you can use a 27c322. Program the rom with the 2 BIOS's, then A20 pulled either high or low will select the different BIOS's.
3 BIOS's would require a bigger rom or multiple roms. The main issue is that the chip enables are pulled high on the 2 roms not being used and CE pulled low on the rom you select to use.
Also very important is that each rom has a decouple cap at its power pin.
Maybe a 47uF cap for the whole rom board too.
