beerorkid
I curl a biz card in the receiver so tilts do not count. I have also loosened the leg bolts a smidge so you can get a good shove. Prob a bad idea on the not tight legs though. I just hate draining.
No!
Do you block the outlanes too?
I hate it when people abuse my machines.. I also consider moving the machine cheating. The only bump that is acceptable is when a ball is stuck. I know some of you will cry foul on this but....
I make sure the tilt is on. If you tilt you loose your ball. If you tilt again... i bannish you from the game room. No shoes in the game room either...keeps people from kicking the machines out of frustration.
I don't but I will set it to warn 2 or 3 times on newer games depending on how rough I want to get with it. I've disabled it on some older EM games but I'm not intending to be moving the machine all over the place with nudging.
Loosening the leg bolts sounds like a terrible idea to me. You're going to damage the cabinet doing that.
Very well put! "Loosen the leg bolts", LOL!!!!! Try putting (wheel) casters on instead of leg leveler's, to get the nudge of ball you want without cabinet damage, just a thought.
Dude... nudging is a HUGE part of pinball... you DO know that, right?
In any case... I leave my tilts alone. I will set newer pins to 2 or 3 warnings, but that's it. There are SOME games that absolutely REQUIRE nudging to play longer than a minute or two (I'm looking at YOU Spy Hunter)...
...or pick up some nylon feet. Marco sells them.
