CrazyKongFan
Hi, I've got a Gaplus cab (in a standard Midway Galaga/Ms Pac type cab) with a 19" G07 monitor in it. Currently, I have a JAMMA cab adapter and 48-in-1 board in it (just disconnected the Gaplus board, but left it in place). I've got a couple of Crazy Kong boards I'd like to play on it, but they play upside down (the 48-in-1 has a switch to play it either way, so it won't matter which way its in). I've never handled monitors before, is it safe to pull one off the mounting rails and rotate it 180 degrees without discharging, or do I need to discharge it first. Also, are they light enough that one person can do it, or will I need 2 people? It looks like I just need to remove 4 bolts to pull it out, then rotate 180, and reinstall the 4 bolts. Sorry for the newbie-ish type question
Thanks!
