do galaxian joystics need to be rebuilt?
patchboston
Ohio
Does any one know what exactly needs to be done to restore a galaxian joystick? I'm at whits end with this thing! I dissembled and checked out the assembly, tweaked the leaf switches (had mild success) and tried a few other tricks, but this thing will just not work. It doesn't look like theres much to the joystick, nor a grommet...arg! Loose as hell >:-(
The joystick assembly has nothing to do with whether or not it's working. You should be able to activate the leafs only and it should move left or right. If it does nothing, you have bad leafs or a problem deeper in your cabinet. It really is that simple!
