Do both controllers have to be connected?
tmcaree
the pas, manitoba, Canada
Ok, so I got the jigsaw characters figured out on my ring king game, Now after doing some soldering and stealing 2 leaf switches from player 2 so I could make player 1 work I have no movement or button response from player 1 whatsoever. Do bothe the controllers need to be connected to make a circuit or something in order for player 1 to work?
Thank you
You shouldn't Have to have both controllers wired up. But, the ground wire is usually daisy chained through all the switches on the control panel. Make sure you didn't break the ground chain.
ok will check that out next, Some of the movements worked b4 I touched it, all i did was replace a few leaf switches and all of a sudden no working movement or buttons on player 1, Thanks for the reply
