Phetishboy
Double Dragon is a great game and a versatile cabinet.
I am a new member that only owns two machines. The first one is a Taito Double Dragon machine that I saved from the dump and restored it's badly water damaged cabinet. After hours of busting my ass I finally got it working. Today I fired it up and the video worked but the sound from the pcb is gone. I ended up trying to check voltages at the sound amp and ended up shorting out the -5vdc on the board. Screw it....I will just get a new board. The next great project was a empty Q-Bert machine that I worked my a** off on to turn it into a 60-1. It worked fine untill I went to push it up against the wall where it would sit..turned it on and it played blind. The chassis went out. I only have two machines and that is all I want. I can't imagine how you guy's with real arcades keep them running...... I'm done.
I have learned to relax enough that the hate part is almost gone. I work on them when I can, but don't get to concerned if they sit. I have 2 projects that I want to finish, but it may take a while. If I can't get them working by the end of next month, they will sit until next summer. I can handle that now. A couple of years ago, it would have driven me insane.
Yep: I'd LOVE to have that Q*bert and restore it back into it's full glory because I HATE that you 60in1-ed it.....
But hey, that's just MHO.
TrevEB; MC: has a loose solder joint in the chassis said:Thats why I always go over every single solder joint on a monitor chassis no matter if I see anything or not. Then recap the monitor as well in the process. It might take up to an hour for me to go over the monitor but the headaches it saves in the long run are well worth the extra trouble.
