redlines
I just got the new swear roms for my DM man. It worked fine before I installed them besides the ball eject from top of the play field would only work when the game would cycle threw and look for balls plus it would make a knocking noise when you first turned it on which you could make stop by opening the coin door and advancing it?
I put the new roms in and now the game won't power up and some of the leds on the power board are not lit plus some of the other leds on the the other boards are not fully bright. I swapped back in the original roms and it still does the same thing. My power cord has a cut in it and you could see one of the wires had been cut and only about 50% of the wire was still connected it was just taped over with electrical tape so I ordered a new one and it will be here soon. Any idea what I should check to try and get it to power back up and any idea what to check with the ball eject or the knocking on start up?
I am new to pin repair so sorry for all the questions. I was able to fix my Joust and Robotron with the help of Yellowdog and Dokert so I hope I can do the same thing with my DM
