I have a DL w a Dexter and originnal DL main & ROM pcb in a game that I'm selling, which all works as it should.
I also have a Sony LDP-1550 and Hi-Tech card that I wanted to test out before I no longer have a working game to see if it could run the original hw to put in another DL project cab. I was able to get my LD player to work with the Hi-Tech card but then it wouldnt eject the disc. I did some searching and watched a few youtube videos and it seemed the belt could be the cause of the problem. I coudnt find a manual for this model, the dlp website didnt have one either. correction: they do have the manul for the UK version of the player, see below in next post/response from @Mavrk
www.bitcrush.io
no manuals found here
This thread had some information but its a wanted thread and couldnt find any other threads for this model unless they were 4 sale posts
Some of the repair videos for other players showed that you had to remove the laser tracking components to get down below the tray to get to the belt. In others, there were tabs you could press to cause the tray to eject but I couldnt find any information for this particular player. Luckily, the belt for this player was on the side of the unit. I was able to manually pull/feed the belt which caused the player to grab the disc and raise it which resulted in the tray opening and ejecting the disc.
Does anyone know which belt is the correct replacement belt for this player? I found what I think might be the one and ordered it. I guess I'll know soon enough if it works but I was hoping someone here might have prior experience. shows P/N 3-534-779-00
Found it here: https://www.smcelectronics.com/autoacc.htm, do CTRL+F for the P/N
Paypal link to order: https://www.paypal.com/webapps/shop...gging_id=f754849f200b3#/checkout/shoppingCart
In any case, of course I kept screwing with it and now when I turn it on, the player wont play the disc. I actually managed to get it to work one other time but its back to not playing the disc upon startup.
Any ideas what could be keeping it from playing the disc?
thanks!
got lucky and when i turned the game on the player loaded the disc and played
here it is now, starts up but won't play...
Sony LDP-1550 - Laserwiki
Sony LDP-1450 or 1550 Laserdisc Player wanted
Have a Time Traveler I picked up where I don't think the laser is reading well. It spins and the disc is clean, but doesn't actually load up. 1/10 times it will get to a picture on the screen for a hot second but then goes back off, so I would assume skipping and a player issue. So, would like...
forums.arcade-museum.com
thanks!
