dkjr popeye question
katoskave
Permanently Banned - Uses multiple accounts to sca
Alaska
will a Popeye pcb work in a DKJR without any mods to the wiring?
There was just a thread on this in the either the restoration or technical forum.
My understanding is that popeye will run in a DK/DK Jr. cab even though Popeye uses a different power supply. I haven't tested it yet but Nerdtendo says his worked just fine.
You'll need to rotate the monitor horzontally (which requires horizonatal mounting brackets). If your machine doesn't have the horizontal holes drilled already I'd be really hesitent to drill them. You don't see DK and DK Jr. cabs with only two holes drilled very often.
The other thing you need is a wiring harness, because Popeye uses and edge connector and DK Jr. uses the multi-connection harness. If you can find one of the harnesses Dockert & Flagg made that would be the best option. Otherwise you'd probably need to modify a DK 3 harness.
Other than that though, yeah, it should work.
The other thing you need is a wiring harness...the harnesses Dockert & Flagg made that would be the best option.
I used my DK's PP7B power supply with the Nintendo Super Harness to run Popeye, Mario Bros., Donkey Kong, Donkey Kong Junior, and Donkey Kong 3 in the same cab. There was a modification availabel through Dokert for using the Popeye PS too.
Also, here is a link to the thread JamBurglar mentioned...
http://forums.arcade-museum.com/showthread.php?t=224615&highlight=popeye
Also, if anyone is interested, Dokert might do another run of Nintendo Super Harnesses...
http://forums.arcade-museum.com/showthread.php?t=228744
