DK3 Wiring...need help
squall280
Pennsylvania
I got a DK3 recenty with graphical issues. So i figured it was the board. Pop the back off and i see someone hacked the wiring up to the monitor. So I figured I could throw the board in my Popeye cabinet to definitely determine the board is the issue. SO it seemed both have similar wiring since its the board in the cage with the outside fingerboard for the wiring. Didn;t seem to work at all. Had no power to the monitor.Which is weird caus ethe Popeye works perfectly. So my question would be is it even possible to swap out the Popeye to DK3 using the wiring?
Unless you pull the wiring from the DK3 and put it in your Popeye and make sure you have the right power supply it won't work. You could also replace your wiring with a DOKERT harness (if you can find one) and play any of the DKs as well as Popeye and Mario Bros. Or get a Nintendo to JAMMA adapter and check it in a JAMMA cab if you have one.
