DK3 help
DKJR
Iowa City, Iowa
so I moved my 4 nintendo cabs into the newly remolded man cave last week and everyone made it fine but the DK3 monitor now looks like this. (picture below) it is gittering up and down continously on the far left side hope you can help anyone out there. Im green when it comes to monitors. Thanks for your help in advance
DKJR
is the horiztal hold on the monitor next to the volume or on the game board it self. Thanks for your quick reply
what tool do i need to adjust that h hold I just called radio shack looking for a monitor adjuster kit and they had no clue what i was after. is there a certain item number or site you guys get that from?
Thanks DKJR
If you shut it off and discharge the monitor, I'm pretty sure you can stick your hand in there and tweak it slightly then turn it on to see if it's better or worse.
I'd do it with the power on, but I know what I'm doing and what not to touch...
could i just use a small screw driver too when its on and just adjust the pot? or should it be a insulated or all plastic flat head?
I adjust mine with a stubby screwdriver, metal head, plastic/rubber handle, with the power on. As modessitt said, if you are at all unsure/nervous about it, turn the game off, tweak the H hold, then turn it back on to check results.
well i just got done adjusting my monitor and its back to normal i would like to thank everyone for there help in saving my money but more important time. I got it to stay steady and no jumping around. It seem like its to big for the screen as the section in the top left corner where it reads time. the e is getting cut off. what adjustment pot is that?
Thanks agian to Dokert and to Mod. for your help and that chart was a life saver.
Thanks,
Tony Rossetti
is that v one of the pots in the same row that has the volume? on the small board in the left hand corner
