DK wiring has been hacked up, worth restoring?
jasonlyvers
Kentucky
I've got a DK cabinet with a rotated Sanyo monitor, a DK Power Supply, and lots of hacked up wires that now run a Jamma Board. I'm planning on rotating the monitor back to vertical and putting a X in 1 board in. Should I keep or replace the DK power supply, keep or replace the hacked up Jamma wiring?
It's depends on how bad the wiring is.
If it was me,I would put a switching power supply and a new Jamma harness from Bob Roberts. Just save the power supply in case you ever turn it back original.
The current Jamma harness is garbage too, so, while I'm sure it will piss me off, I think I'm going to go with a PS swap and new harness. Are you aware of any guides on connecting a Jamma harness to a Sanyo monitor? The cables are spliced up pretty bad right now, will be a nightmare to document and then recreate.
Try to find a replacement DK harness. Once you get that, you are golden. It's plug and play.
He wants to put X in 1 board in the cab and that can't be done with an original harness.
Also if he has a DK boardset he can still play it with a jamma adapter.
Original harnesses are hard to come by.
