DK side art and coin sticker placement
vader1979
Donor 2021, 2023
bismarck, North Dakota
Does anyone know the correct measurements to apply DK side art? Also would like to know the correct location to place the coin sticker on front of cab....i've seen some right in the middle..some in the middle but close to bottom...and also some over on the right side...would like to know which is correct...thanks!!
All of this stuff varried slightly at the factory.
A lot of people go off the old flyers for placement of sideart, but then you'll see post where people have original factory installed sideart and it placed slightly differently.
I've seen Nintendo cabs with two coin stickers and cabs with just one. I have serial number 01667 (red cab) and there was only one coin sticker set in the center. I can give you some measurements if you want.
Yes please...measurements would be great! My serial number is 01237...so ours are pretty close...main concern is correct placement of side art...will put coin sticker in dead center...
QUOTE=JamBurglar;1927816]All of this stuff varried slightly at the factory.
I've seen Nintendo cabs with two coin stickers and cabs with just one. I have serial number 01667 (red cab) and there was only one coin sticker set in the center. I can give you some measurements if you want.[/QUOTE]
I went off the flyer and have seen a few with original side art and the same placement.
Some like it much higher and you should try different positions and decide where you like it.
Here is mine.
I centered the Donkey Kong letters with the lower marquee bracket and then centered it front to back.
attachment.php
The top of the coin sticker on mine was 6 cm (about 2 1/4") from the top of the front panel.
I don't have original side art on mine but you can check the "Radar Scope Tag Data" thread. There are some people on there with original DK side art on the red cabinets with pictures showing placement.
thank you! read that entire thread relating to dk data...learned alot...and thanks for the coin sticker measurement!
