DK Record . . .for me at least.
My "record" is around 130-140K... I've only gotten past the 3rd stage elevator level 4 or 5 times... I mostly hang around 85-95K...
I remember when I was stuck in the 40's. You can get damn near 90k before the third elevators if you use all the point pressing techniques. I've only gotten past that screen once on luck and made it to the 110's.
Wonder if you all can reach the killscreen?!
I cannot yet clear the 3rd elevator stage. I usually do 80k - 90k. I don't have a lot of time to play it either.
If you have a high score kit set your lives to unlimited and get to the screen you want to improve on and then keep practicing it until your comfortable with it then reset the settings to default and watch your high score climb.
if its the 3rd elevator, then get your when to run timing down and don't go all the way to the top of the ladder, rinse and repeat, or the rivet level don't pop the last rivet. Just kill your man off before finishing the screen.
I'm stuck at 521K for now want 600 buy end of the year.
Andrew
