DK questions
baiterhater
swindon, wilts, United Kingdom
Hi guys
I could do with a little help
Ive managed to pick up a nice little DK which over here in UK is not very easy at all, took me over a year to find one. Anyhow the game is all working but for some reason the loom has been hacked about big time, my guess is that it was a micro connector type and someone has poorly connected an edge connector, is there any reason for doing this ie were the micro connectors troublesome ?? id like to put the cab back to original as the job is piss poor on the control panel the wires are connected with selulotape. Ive worked out via the manual what parts of the loom im missing.
Im also missing the service switch that connects to P8 where on the cab is this located ?
Also the monitor see the monitor is missing its rear bracket and earth(ground) connection but there are also three other holes right through the cab on both side is this also for monitor brackets ?? if so how is the bolt arrangements are they behind the side art or do they go through.
Can anyone send me or point me in the right direction for some pics of how a DK should be inside? also can you tell what or if else im missing
Many thanks and sorry for the dumb ass questions but there just arnt any DK's over here to compare to.
Anyone got any of these parts give me a shout !
Cheers
Justin
The service switch should be located on the coin door between the mechs.
The extra 3 holes on each side are only needed if the monitor is mounted horizontally.I filled them in when I repainted my DK. This is what is needed to mount the monitor properly.http://www.mikesarcade.com/cgi-bin/store.pl?sku=MONXBARN. The bolts were put through the side art from the factory. You also need this,if you don't have it already.http://www.mikesarcade.com/cgi-bin/store.pl?sku=MONMNTN
These are the only pics I have right now,my DK is still tore down.
It looks like you just need the rear monitor brackets and an original harness,if you want it original.
I would use it as is while I looked for a harness.
