DK question that might make me look dumb...
NERDtendo
Republic, Washington
I have an original harness that I acquired for my DK restore. I was going to use my Dokert but then this one came along so I decided to go all original on it and save the Dokert for another project. My harness that I received has three parts. One is for the control panel and the other two are power connectors (I believe). I had originally thought that I didn't have the whole harness because I saw others for sale that had like 7parts to it. I went to preparing my cab and saw that I had the parts for the service switch, coin meter, coin mechs, video, and audio inside the cab. I felt dumb then because I was about to yap at the person I bought the harnss from. Anyways, my question is...
do both or the power connectors get hooked up to the board or is it like a kit made for multiple types of power supplies an you use one based on the PS you have???
This may be vague, I can take photos or provide other info if need be. I have to go to the hardware store next week to get the last couple items I need and I can get this game put together. I just didn't want to mess up my PCB by supplying too much power or something dumb like that.
I believe the original harness has 2 power plugs, one for each side of the pcb.
That's what I thought. I just need someone to flat out confirm this for me before I plug it in. DK boards ain't cheap. Thanks for the confidence builder though. Anyone with a DK who can chime in???
10 pin (10P) connector goes from the power supply to the video board and the 9 pin (9P) connector goes from the power supply to the CPU board. You shouldn't be able to mix them up.
9P to P9 on CPU board, 10P to Video Board.
Murph
Murph
Awesome. Thank you for the confirmation.
Now onto wiring up the DK...sometime...I worked on the GamRoom/Living Room too much today.
