DK problems... Need help...
CalifTom
San Diego, California
I could use some help with this DK problem. I have cleaned and reset all the socketed chips and I am still getting this junk on the screen. It does coin up, but I do not hear any music or jump sounds as if it were playing blind. Any suggestions on where to start. Thanks for the help.
Pull 5B and 5C one at a time and see if it stays the same or changes anything with either one.
I had 5B bad on mine and it looked very close to your picture, one of my friends checked it with a burner and it was indeed corrupt and was able to erase and reburn it.
If you haven't done so already, you should check your Voltages.
Thanks for all of the suggestions. I will try the suggestions that I can do without having to order replacement proms. I'll report back with my findings.
