DK Monitor Shaking
simpsons99
Snohomish Washington
DK Monitor just started Shaking when turned on it's like a mine earthquake on the screen from side too side. I switched over too DK2 it stopped doing it for like 2 mins and then started on it.
any help i would be most greatfull thankyou everyone!
Attempt to adjust the horizontal and vertical hold pots - you might have a flakey one. Don;t forget about the pot almost dead center on the monitor chassis as well. (sorry forget location name).
Also - check the b+ voltage.
I did'nt know we have a Monitor fourm intell after i posted this. I figured it could be the monitor or something else.
BTW i noticed it does it more when Jump man/Mario is Wacking something with his hammer.
might be your sound amp. I think I know what you're talking about. try turning the volume all the way down and see if it goes away.
happened on my top PC-10 monitor whenever lots of sounds would play, figured it was double mono anyway so I turned it down. I reckon the sound section needs to be recapped.
