DK machine: Should I Paint or Cover sides? I saw a collector's paint job. It looked minty. A lot of time spent though. Wondering has anyone had experience with the blue covering that's out there?
not sure what blue covering you speak of. If you mean vinyl then I suggest you just paint. Vinyl requires you basically get the surface flawless and do all the same work you would do for paint. Including paint. Once you have a perfect painted surface then you can apply your vinyl. Simply painting is a bit more forgiving and will still look good. Plus closer to original.
