DK Jr Wiring advice needed
icust298
Ankeny, Iowa
I've got an old Vs cabinet that I've been converting back into it's original DK Jr self. I've got the wiring harness from Bob Roberts and I plan to finish this up this weekend. I've only got one connector coming out of the 9P labeled connector on the original nintendo power supply. I checked my original DK and it has connectors in both 9P and 10P. So my question is, can I wire my harness up using only the connector in 9P or do I need to pick up/make a connector for the 10P portion of the power supply?
I think that if using a harness with an edge connector -> PCB, you would only need the one power hookup, so that sounds right.
or if its the harness without the edge connector you can use just the 9p if you have the rainbow cable connecting your boards...
