squall280
I recently picked up a dkjr cab and its particle one. The cab needs some work that bondo will assist but I have issues on the inside. Both the shelf on the bottom that holds the coin box and the shelf on the bottom of the monitor have pulled away from their groove on the one side of the cab. Obviously its the one side of the machine that filled away but I would like to resink these into there grooves. The side really isnt that bad and there is no signs of moisture. What I attempted to do was to pull them in with screws but I couldn't get them exactly in the grooves. The plan is to resink these two shelves and paint the cab with leftover appliance paint to get. Strong enamel base and then reprint it Orange. Can someone assist with the shelving issue?
