DK jr. marquee light
Shavenyak
Donor 2023
Sarasota, Florida
I seem to have a voltage issue in the electrical sockets in the bottom of the cab. Both the monitor & light works plugged into either outlet. The marquee light works when plugged into an outlet outside of the cabinet. It won't light when plugged into the cab if the monitor is plugged in. I'm guessing the power supply is having a hard time putting out enough voltage when both are plugged in. The interesting part is that the power supply doesn't power these. The outlet is wired directly into the transformer. Any suggestions?
Power supply doesn't power those. There's a transformer that drops the voltage down from 120VAC to 100. That light fixture and monitor are supposed to run on 100VAC. I have successfully used a 120v replacement fixture (from Lowes) and it worked ok plugged in to 100VAC.
With the game on, monitor plugged in, check the outlet for the light with a meter. If it reads ok, then it's the light fixture.
