DK JR Cocktail no monitor can I hook up standard CGA?
GuSH
Coatesville, Pennsylvania
Title says it all have a DK JR Cocktail no monitor installed is there a way that I can hook up a standard CGA?
the dkjr cocktail used an 18" sanyo monitor with inverted video, it would be possible to hook up a normal monitor, but it probably will not fit in the cocktail cab.
a sanyo 18z2ab is one of the original monitors used in the ct.
I have a brand new one that will fit except the plug for the video in the cabinet is square and not the normal RGB and sync and the speaker plug is loose and if I remember correctly it plugs into the nintendo monitor chassis?
it may be better to replace the original harness with a jamma harness and a jamma adapter that has the inverter and audio amp. then you can sell the original harness to someone who is trying to unconvert one, but has the original monitor.
the beautiful thing about that table is how easy it was to rotate the monitor from horizontal to vertical and back again.
I ended up picking up a Nintendo 19" tested working in my Nindendo Player Choice. Below is the garbage I am getting when connected to the DK JR...
That's just a sync issue. Simple to adjust out. Start with the H and V freq. pots.
