ckong
Is it possible to put a DK jr. and a DK3 game board in an original wired DK cab, without having to change anything on the wiring and monitor setup?
It can be plug and play with an edge connector. DK and DK Jr may have the single connectors that go to the pcb. DK3 came standard with an edge connector.
All depends on your wiring.
I have a DK 2-board set with the edge connector, but my wiring is the original style. How hard is it to convert from the original to the edge connector? Trying to weigh the pros and cons of doing it so I can pick up JR and DK3 boardsets.
Yes those will work just need to turn the monitor to horizontal for them.If I convert to the edge connectors, can the other Nintendo games (MB, Popeye, though those would require a monitor rotation) swap in as well?
Thanks guys to step on board of this topic.
If I filter all the info above which is not important for me I believe the following is true: Yes, I can put DK jr. in my DK cab (which has no harnas with an edge connector), but I need a harnas adapter in order to be able to play DK3 (I dount want to adjust the existing original DK wiring).
This is the adapter you'll need. Speath (HudsonArcade) makes them:
Good luck, I've been waiting for these for a long time. I think he's too busy, er something.
http://www-mtl.mit.edu/~mspaeth/pics/projects/New_Stuff/PICT0667.JPG
