DK Convergence Issue?
kentmurphy
Missouri
thanks dokert ... should I slide the yoke toward or away from the tube? ... or should I just play with it?
Could be the ring assembly that got bumped too.
Sometimes you can loosen and rotate the entire ring assembly. (NOT the individual rings unless you have to)
thanks guys ... I give your suggestions a try in a day or two and report back ...
tried to fix this issue today ... After several attempts to converge it with the monitor connected to the DK, I decided to connect the monitor to my Mario Bros machine ... Mario Bros has a self-test program which has CRT test screens that allow you to adjust the colors and the convergence ... The colors on my DK weren't right, but this allowed to get the colors spot on .... Convergence was another story ... I had no problem getting the monitor statically converged, but dynamic convergence was a problem ... I thought I had it when I glued down the wedges and tightened the rings, but after putting it back in the cabinet I realized it was still off ... 3/4 of the screen looks good, but the lower right corner is not good ... for now it will have to do ...
one question ... what would be the quickest way to correcting my problem or is my only choice to start over? ... could I use those magnetic strips?
Kent
