DIY GBS Control RGBS Sync question
aapuzzo
With the GBS-Control. If I add a SCART on RGBS port I read that I need to add a 100 ohm resistor. If I get the Retrotink hd15 to SCART cable that says it has 470 ohm resistor on sync pin 20 do I still need the resistor 100 ohm resistor on sync in the GBS-Control? I want to use this device with my HAS 5.1 and a Sharp X68000 that I am getting. The sharp x68000 uses the RGBSHV port and when you use this port you don't want that resistor installed. I also don't want to break anything. I live in the US so I don't have much experience with SCART.
