Dixie Narco 440 - Condensation inside?
tinsley
Connecticut
I have a DN 440. Opened it up today to put some drinks in and water came rolling out. Seems the catch tray (not sure what it is called, flat area under the loading slots) was full of water. What could be causing such a build up of water inside it?
High Humidity.
If it's too high, you'll have to periodically dump the catch pan.
Water build up is a sign of humid air getting inside possible door cracked open or bad door gasket, flapper door stuck open or bad seal.
