configurethis
Looking to replace the pins in the two top connecters (male incoming) on the power supply of a Discs of Tron uprite game. I have troubles using a .093 pin remover. I could not get them to release. And also any suggestions on removing the female conn on the board itself. I have added and removed fresh solder to no avail.... Turned solder station temperature up rather high as well.
Any help is welcome!
Thank you
Thank you
